XpresRoute_Length_Variable needed
In XpresRoute I modeled a part with the Length of 375.25mm
Under Varables -it stil seems for me- there is no varialbe with the needed distance of 375.25mm
Did anyone know how to achieve it?
Yasser
3 REPLIES 3
Re: XpresRoute_Length_Variable needed
I'm pretty sure, when I did this in V17, you can use a property text and use a variable called "tubelength".....
Many thanks for your Message!
We will see if it will be possible to be able to have access to "every" parameter in Solid Edge Smiley Happy
Yasser
I could find the solution!  Smiley Wink
