Zones issue?
Hi Edgers,
just noticed that already created zones, when they are hidden or the View zone/hide zone button is turned off, they are gone and aren't able to turn on.
Maybe I am wrong or do not know something.
Can you please confirm that this behaviour is correct?
thanks
Arek
6 REPLIES 6
Betreff: Zones issue?
Hi @arekkul
20180427_1000.pngView Configuration20180427_1001.pngSelect Tools20180427_1002.pngView Tab
Wolfgang
Hi @hawcad
thank you for a quick reply.
The problem is I cannot use a button from a View Tab - the button has stopped working.
Arek
Hi @arekkul
could it be that You have a different license?
Zones are only supported with Classic and higher but not with Foundation
Wolfgang
Hi @hawcad
I have Classic one.
regards,
Arek
Hi @hawcad
ahhh, I found the problem, sorry for bothering you Wolfgang ;-)
I've hidden the Zone boxes using Show/Hide all components command.
Such a silly me Smiley Wink
regards,
Arek
Hi @arekkul
OK, this is something I have not thought about.
But You have fixed it and found the solution, great!
Wolfgang
