activate part hides in st8
I am using solid edge ST8, assembly.
When i want to use project sketch command in assembly I go into the part and try to project edge of other part on current part but i cannot select that part coz its inactive,
If i activate it using activate part command from ribbon it still dont select it.
then i tried to activate assembly by right clicking and selecting activate but instead of activating it hides the part. I dont know how to fix this problem, any help?
Re: activate part hides in st8
Have you tried turning Peers ON ?
