add lettering to a part
how do i add lettering to my parts i have drawn up?
Re: add lettering to a part
Hi @Deawn,
Are you working with a 2D only part drawing?
.....easy enough to add the text, using the "Text Profile" command, BUT, there is a work-around required, in order to remove the [rediculous] default "boundary" box.
