animation of conveyor belt
Hello all,
Please help me to do animation of conveyor belt. I have attached the assembly file. I want to animate the movement of belt as two wheels rotates.
Thank you,
Re: animation of conveyor belt
Hi Sandeep,
According to me, if you want to make the belt rotating as your gears rotation, you need to create the belt like a chain single part and assemble it as a chain, can not be a one part belt right away.
