ansys workbentch R18.1 can not open ST9 file
Hi all ,
I'm trying to import ST9 part file into ANSYS Workbentch r18.1,but it encountered below error ,according to the ansys helper ,ST9.par should be a supported file format. May you any suggestions for this case ?
Thanks all !
Re: ansys workbentch R18.1 can not open ST9 file
BTW ,ST7 can be opened successfully ,I'm not sure whether there should do some settings in ST9.Cat TongueCat TongueCat Tongue
Having no idea of how you intend to use the imported part in Ansys, if any features, etc. are required downstream, the part can be exported from Solid Edge in a neutral format like Parasolid and imported into Ansys - as a workaround.
Do you face this problem with just a specific file or other ST9 files as well ?
In that case, you need to send the ST9 part to Ansys support to investigate why it won't import.
Lastly, for a 'fatal error' kind of error, check if cleaning the %TEMP% folder followed by a computer reboot solves the issue.
~Tushar
Esteemed Contributor
We are running Ansys ans SE ST9 and don't have an issue getting ST9 files to work with Ansys.  I suggest you contact your Ansys Support provider.
Production: ST9 MP10
Testing: ST10 MP3
