arrows?
Not applicable
Is there a way to draw an arrow as easy as a line?
Re: arrows?
Not applicable
Hermann,
What are you trying to do with the arrow? Do you plan to attach something
else to the arrow?
Rick B.
Re: arrows?
Not applicable
"Ricky Black" wrote:
>Hermann,
>else to the arrow?
>Regards,
>Rick B.
>Hello Rick,
as I mentioned once before in this forum, i like to use se2d for sketches for structural
calculations. So I need arrows to symbolise forces. Attached you find an example.
By the way
To draw an arrow, I draw a line and a triangle and then I fill the triangle. Then
I block these elements.
Hermann
Re: arrows?
Not applicable
Herman, try either a connector or leader under ANOTATIONS. You have choices as to
how the start/stop ends appear.
Ron
>>Hermann,
>>else to the arrow?
>>Regards,
>>Rick B.
>>Hello Rick,
>for structural
>By the way
>Then
>Regards
>Hermann
Ronald W Latour
