automate export of parts to different dxf files
just started using st9 2d drafting. i am drawing parts in drafting and linking the parts so when i change one paramenter all of the parts will resize. what i need to know, if possible, is how to automate saving each part into a seperate dxf file. i can do this manually by drawing on different layers, turning layers on and off, and saving to seperate dxf files. would like to know if this could be done automatically. thanks for any help
Re: automate export of parts to different dxf files
Could be done via writing code to automate using Visual Studio or similar if your license provide the API.  No built in functionality to do that.
If interested in writing code, post to the Solid Edge Developer Forum.
Production: ST10 MP9, Testing: SE 2019
http://Grundey.blogspot.com
i think there is a free version of visual studio. regardless, as i have no idea how to write code, i will do it manually, lol
thank you for answering.
