blocks appear on one layer in autocad
Hi Guys
I have been using free2d for some time now but i now need to start exporting in dxf or dwg format and am having some problems.
In free2d i create all my blocks on the default layer then save them to the library and use them on layers as required and this works fine, however when i export to dxf or dwg and open in acad and then try turning layers off nothing happens. if i turn off the default layer all the blocks turn off.
Any ideas would be much appreciated
Re: blocks appear on one layer in autocad
Can you provide an example?
You can send it directly to me.
Rick B.
