can not log onto the SE forums discussion groups
Mervin D. Yoder
CAD | Designing
keimlumber ST9
If you are using IE, make sure you have compatability mod...
Esteemed Contributor
If you are using IE, make sure you have compatability mode turned on.  It is working as I log in every day.
Production: ST9 MP10
Testing: ST10 MP3
Re: If you are using IE, make sure you have compatability mod...
Here is the message I get after the password is entered. -Mervin
[cid:image001.jpg@01CED941.83312220]
Mervin D. Yoder
CAD | Designing
keimlumber ST9
Your image did not post.
Testing: ST10 MP3
I am pretty new to this, what is the best way to attach an image.
Mervin D. Yoder
CAD | Designing
keimlumber ST9
Hi Mervin,.....as I see it, this is a "FLAW" in the system design, as far as images in the comments section go. Unlike when posting the original question, users can only add an image through this system when in "Edit Comment" mode.
I recommend you contact your VAR, to make sure you're on active maintenance.
Like Ken, I log into the SE Forums each day with no problems. [using IE9]
OK Thanks for your help on this. -Mervin
Mervin D. Yoder
CAD | Designing
keimlumber ST9
