can not select part's
N/A
I am a new Solid Edge user that can not select any parts in 2d modeling or in drafting mod. Did I lock it down or change layer settings. Worked fine at first now all I can select are the dimension’s can not readjust any parts I have created. HELP!!!
Re: can not select part's
When first picking the Select tool, click on the Filter option on it's command bar. You should see several classes of items to check/uncheck for selection.
Sent from my Motorola Electrify using Tapatalk 2
Production: ST10 MP7
Testing: SE 2019
http://Grundey.blogspot.com
