cannot convert to pdf
Not applicable
I can not convert my .dft file into .pdf file in my solid edge ST4. It says that XXXfile can not be saved due to a file translation error. Someone help me?
Re: cannot convert to pdf
I don't know which pdf converting control and platform you were using, so can you provide more details?
Or I just search two related resources, you can have a test.
PDF converter with C#
PDF converting in vb.net
Hope it will be helpful.
Best regards.
Hi there,
Can you not just re-install the software? [if you have it saved]
What about upgrading to the latest version of Solid Edge, compatible with your operating system??
[32bit Windows = ST6 / 64bit Windows = ST7 onward]
Solid Edge 2019 [MP8] Classic [x3 Seats - Cloud Enabled]
