cant open st3 project in st4 version
Not applicable
Hi I can't open my project created in solid drafting st3 under solid drafting st4,
I can't find st3 version anywhere on internet
Re: cant open st3 project in st4 version
I assume by the term project, you are refering to Draft file. Correct?
Can you create a new Draft file in ST4?
Are you seeing this problem will all Draft files created in previous versions? There should not be any issues with opening these files.
Rick B.
Not applicable
I had an evaluation DVD for ST4, which has now expired. Now that I have Free2D I can't open any drawings that I did with the evaluation software.
Peter
What version of Free2D?
http://Grundey.blogspot.com
