cant open.
Not applicable
hey.. i cant seem to open my program.. its like, er.. it say its corrupted
what to do??? i need fast..
Re: cant open.
Not applicable
Alex,
Is the problem that you can't run the downloaded executable to install? Or
have you installed the software and the software will not run?
Rick B.
Re: cant open.
Not applicable
"Ricky Black" wrote:
>Alex,
>Regards,
>Rick B.
i cant run the installation. i need it fast man.. thanks.
Re: cant open.
Not applicable
Alex,
If you think it is corrupted, you can download it again. Simply go back to
the web site and go through the steps to download the executable. It is OK
to register again.
Rick B.
Re: cant open.
Not applicable
>Alex,
>to register again.
>Regards,
>Rick B.
is there a file you can tell me to down load.. there is alot.. and i thought mayb
you can infome me the main program so i wont make anymore mistakes??
Re: cant open.
Not applicable
Alex,
When you go to the free2D web site and register, you will download called
SE2DDraftV100ENGLISH.exe. This is the english version of the software. If
you downliaded a different language, it will have your language name instead
of ENGLISH. This is the executable you run to install the software. Once it
is installed, you run the software by clicking on Start-All Programs-Solid
Edge 2D Drafting ST-Solid Edge 2D Drafting.
If you do not have the executable to install the software, you can go back
to the web site and download it again. you wil have to register again, but
it is OK to do that.
Rick B.
