cant select parts
i want to bulit a car and the the parts and want to built it in the .asm.
The thing is i cant select things to fit them together, i dont now what to do.
I already reinstalled the st9
Betreff: cant select parts
HI @Crosshair
I think You have to give us a couple of infos more to help.
The question are:
  • What really to You have already?
    (parts, assembly,)
  • Where are You working in the moment?
    Within a part, in an assmebly, ..
  • Where are You not able to select part?
  • What are You not able to select?
  • Do You have pictures, filesetc., to explain?
Wolfgang
Re: cant select parts
as @hawcad states we need more info:  but as a guess your parts may not be active.  must be active to mate.
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
