constrain move
Not applicable
Is there a way to constrain the moving of an object, say along an axis?
Re: constrain move
Not applicable
Depends how "permanent" you want this constraint to be. If you just want to
move something in X only at the moment, use the Move command (Second icon
from bottom, looks like four arrowheads). Select your stuff (with fence or
ctrl) and give the "from" point. You will get gray alignment axes to move
just along X or Y when you are lined up with them.
If you want something more permanent, then you would constrain your object
to a line. You probably would need to read about "relationships" in help on
how to do this.
DS
"Pete Swenson" wrote in message
news:45d0e324$1@bbsnotes.ugs.com...
Re: constrain move
Not applicable
Pete,
In addition to Dan's comments....after you select the "from" point you can
hard key a value of '0' in the X or Y box to lock you movement to a single
axis.
David
"Dan Staples" wrote in message
news:45d0f9ec$1@bbsnotes.ugs.com...
> to move something in X only at the moment, use the Move command (Second
> icon from bottom, looks like four arrowheads). Select your stuff (with
> fence or ctrl) and give the "from" point. You will get gray alignment axes
> to move just along X or Y when you are lined up with them.
> on how to do this.
> DS
