Re: conversion doubts in sheetmetal
@bshand : sir could you just explain the process in the video mode . i am not able to solve this
Here is a short video about steps:
Important!
  • Tolerance is 1,00e-001 mm
  • Don't use Dimension tab toggle off it!
BR,
Imics
Honored Contributor
Honored Contributor
AutoCAD does some crazy stuff with its linework. This is the cost of updating the prgrams over 30 years and being backward compatable.
thank you sir @Imics that was great. really worked out
