convert a facet Body to a solid
How do I convert a facet Body to a solid so I can move it to Sync?
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
By "facet body" I assume you're thinking a Obj. 3DS (Poly...
By "facet body" I assume you're thinking a Obj. 3DS (Polygon Mesh) or an STL format file? If so then you're out of luck.... see my Smithsonian Thread here: http://community.plm.automation.siemens.com/t5/Solid-Edge-Discussion-Forum/Smithsonian-Models/m-p/24...
Re: convert a facet Body to a solid
For the future, you'll be able to convert scan data in .stl format in ST10 with reverse engineering:
https://community.plm.automation.siemens.com/t5/Solid-Edge-Blog/What-s-New-in-ST10-Reverse-Engineeri...
Kind Regards,
Jack Stark
Majenta PLM - Siemens Platinum Business Partner
http://majentaplm.com/
Betreff: convert a facet Body to a solid
Honored Contributor
Honored Contributor
Hi @ngardner
in the meantime (ST9) try to import this STl file into a part.
This imported body - at the moment - is not be usable for "anything".
But, export this geometry to ICF and import that one again.
This - at least it worked for me - does a good job, even with ST9
With ST10 - as mentioned - this issue wwill become easier.
Wolfgang
