creating one solid body from an assembly
I know there is a lot of topics talking about this. But I tried all the options I saw and still not working.
The thing is, I've got a huge assembly (around 3.000 parts) and i need to send it to a costumer. I would like to send it as a one body so he can't change anything.
I tried to save is as a part but when i open it, there is a lot of construct bodies (like 1.000 of them) and it looks like a mess. Also, I tried to merge the bodies but it crashes saying something about booleans.
There is any easy way to do it?
Kind regards
J
Re: creating one solid body from an assembly
Hi
Then in the Pathfinder
Click the right mouse button
Save As.
Simplification supports single storage in Par format.
It may not be a good way.
It's just one way ... ^^
The best thing is to support [* .par] when saving with a different name.
Thanks for your answer, I did it but stills saving most of the bodies. Any way to merge them?
Can you use the Part Copy command in a part file? Create a new part and use the Part Copy command. It will allow you choose an assembly file and bring it in as a single part copy feature.
Greg
Hi
There are assemblies that can not be loaded in this way.
Especially for large assemblies, an error occurs when loading.
I need a countermeasure here.
It freezes every time I try to do it. I guess there is a problem with big assemblies.
Would it be possible to save as a .stp file, and then open with a .par template to create it as a single part file? I thought I'd done this before, but sometimes forget my own name............
I've used Edge Publisher.  It's a 3rd party software.  You can ask for a trial and try it.
https://edgepublisher.com/
Brian Fritz
Solid Edge Certified Professional
ST10 latest MP
