curve default values
Not applicable
Hi guys
i am using curve with "rigid and 10 degrees" a lot at the moment but the default is "flexible with 3 degrees". Is there a way to customise the default values to avoid setting them each time I start a new curve. (SE2D ST5 free)
Cheers
Pete
Re: curve default values
Pete,
Currently these are not remembered and there is not a way to preset them.
Rick B.
