cut-out border width line in draft
Experts, I cant find it..Still printing width line for cut-out border. Where should I change it to thiner line? ThanksSmiley Wink
1 REPLY
Betreff: cut-out border width line in draft
HI @cbdu
I only can show it in a German version of SE, but You will find it - I'm confident!
For a single view go to "Properties - Annotation and change those value for the view edge display to - e.g. Normal
In general You can change it under Options - Annotations
This should bring You the requested results.
