detail view command not working
Hi All,
Detail view command is not working in ST9 Solid edge 2D. Can any one offer any help. Is there any service pack which need to be updated to solve this issue. if so please let me know the link to download.
Thanks and regards
Re: detail view command not working
Esteemed Contributor
Hi there @Bhanu-Sesha,
Are you sure you have used the correct procedure to place a detail view?
  1. Create your 2D geometry on the "2D Model" sheet
  2. Place a view of the 2D model on a "Working" sheet
  3. Run the Detail View command, mouse over geometry to pre-select the 2D Model View, then sketch your detail shape
  4. Place the Detail View at the scale & location required
Solid Edge ST10 [MP5] Classic [x2 seats]
