detail view
As we get principal views of a part or assembly when wecall it in draft env, simillary can we get principal view of the detail view on the same drawing sheet?
I am using ST8
Thanks and Regards,
Ashish Sarode
3 REPLIES 3
Re: detail view
Hi Ashish:
Can you post an image of the principal views derived from a detail view to understand the requirement better ?
~Tushar
Re: detail view
Hi Tushar,
Thanks for the reply, but I need to derives more views of the detail view itself.
For example if I have a detail view named A, then I want front side and top view of A.
Thanks and Regards,
Ashish Sarode
Re: detail view
You can't fold another fiew from a detail view (ie. create a principal view)
You can't create an auxilliary view from a detail view.
You can cut sections.
This is on ST7 - may have changed in ST8 ?
HP Z420 16GB RAM
Quadro K4000
