diameter dimension
Not applicable
I use 2 decimal in my drawing ( for example 2.00 ), but all diameter dimension don't show any decimal at all , is there any way we can change to match my drawing?
thanks
Hongmei
Re: diameter dimension
Not applicable
Right click on the dimension -> Properties -> Units -> Zeroes -> Tick trailing.
Also when you are using a dimension tool, On the command bar, set Round Off to .12
