Reply
Solved! Go to solution
dim arrow direction
I remember it was a setting for dim arrow direction. For small radii (see dim.jpg file attached) I want the arrow to be on the same side with the text (outside of the radius).
Thank You,
Marian
Solution
Solution
Accepted by topic author cimarian
‎08-26-2015 04:32 AM
Re: dim arrow direction
You should be able to click and drag the arrow to the outside of the radius.
Kyle
Kyle Joiner
IPA LLC
ST9 MP1
I quickly looked for an option to set this in the Style, Dimension settings, but didn't see anything there. Maybe I missed it...
If there isn't an option to default it there, I don't know where to look.
Jason
no you didn't miss it. it's been like this since ST1 i think. i know people reported it
Yes it works this way. At list can be changed one by one. It was useful to have a setting to get the result automatically.
Marc
Solution
Solution
There is a "jog" option on prompt bar at using Smart Dimension. Try this, it should works well!
A short video about this:
BR,
Imics
Yes it works perfectly, thank you.
Marc
