dimensions on drawings
N/A
I´m new with 2d and I would like to know, whether I can have my geometry (drawing)
and all my dimensions on seperate layers to remove (or subpress) easily all dimensions?
Is there any possabity for?
I´m lloking forward for any instructions and/ or help.
Best regards
Joachim
Re: dimensions on drawings
N/A
Yes, this can be done. Make sure Edgebar is on, and click on the Layers
form tab. Use the form to create, turn on/off, or make active your layers.
You will see one layer by default called "Default". When placing the
elements, set the appropriate layer you want them placed on as active by dbl
clicking the layer name in the form. If you have already placed some
elements and they are not on the correct layer, select the elements that you
want to move to a particular layer and use the "Move Elements" button on the
top of the form to move them to that layer.
http://grundey.blogspot.com
"Joachim Koerner" wrote in message
news:45bcfbf6$1@bbsnotes.ugs.com...
> Hi,
> (drawing)
> all dimensions?
> Best regards
> Joachim
