drawings borders
N/A
Does anyone know if it is possible to develop your own drawings borders? If not,
Is it possible to edit the text in the ones that come with the software?
Re: drawings borders
N/A
Yes,
You can create any kind of border you want. The border is usually located
on the background sheet which you can access via the tabs at the bottom of
the sheets. If you don't see the background tabs go to View-Background
Sheet
"Chris Cameron" wrote in message
news:454fd3e0$1@bbsnotes.ugs.com...
> If not,
> Thanks
N/A
Very easy. We call these "background sheets".
go to View --> Background Sheets
Notice at the bottom of the window there are now tabs now for the various
sheet sizes.
If you click on one of these you'll see that its just like a regular sheet
but watermarked with the word Background.
You can edit the elements however you want.
To decide which background your main sheet is pointing to, Right click on
the tab for your main drawing sheet and choose Sheet Setup
Then go to the background tab in the dialog and choose the correct
background from the pulldown tab
PS> You will want to save this in a Template file so thatt all new files
will inherit same
DS
> If not,
> Thanks
N/A
Thanks.
"Dan Staples" wrote in message
news:4550f079@bbsnotes.ugs.com...
> sheet sizes.
> will inherit same
> DS
>> If not,
>> Thanks
N/A
Thanks. I'll give a try.
"David Rieschick" wrote in message
news:45509093$1@bbsnotes.ugs.com...
> Yes,
> Sheet
>> If not,
>> Thanks
