error 2738
Not applicable
Installing the V20 I get the error "2738".
Someone could help me?
My system: Windows Vista Home premium.
Stefano
3 REPLIES 3
Re: error 2738
Not applicable
Hi Stefano,
Try the solution listed here and see if it helps:
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=1795235&SiteID=17
Jason
"Stefano" wrote in message
news:47308dc8$1@bbsnotes.ugs.com...
> Thanks
> Stefano
Re: error 2738
Not applicable
Thanks Jason, I had the same problem installing on Vista and the Microsoft site helped
once I ran the commind line in administrator mode.
"Jason Zakibe" wrote:
>Hi Stefano,
>Jason
>> Thanks
>> Stefano
Re: error 2738
Not applicable
Hello all,
i'have the same trouble on my pc under windows xp pro.
i run this command : regsvr32 vbscript.dll
and all the setup of solid edge works fine.
best regards
>site helped
>>Hi Stefano,
>>Jason
>>> Thanks
>>> Stefano
