etch in sheet metal
Builder
Builder
When I place an etch on a sheet metal panel (to represent a cross-break), it shows in 3D part and in the draft drawing but not in the assembly. Can any one explain why and can this be changed?
Re: etch in sheet metal
The etch result is curves, so you should show curves in assy. RMB on sm part and select Show/Hide Components from context menu and here toggle On Curves an OK.
BR,
Imi
Imics
Builder
Builder
That did the trick.
Thank you,
Michele
