export files to step
PLM World Member Genius PLM World Member Genius
Hello everyone,
I am using a small program se_export to save draft file to pdf an dxf. Does anyone know a similar program which converts part files and/or assembly files to step?
Re: export files to step
In the Solid Edge installation folder is a program called Batch.exe
Program Files\Solid Edge STx\Custom\Batch\Bin\Batch.exe
You can try that.
See this blog post:
https://community.plm.automation.siemens.com/t5/Solid-Edge-Blog/Translating-Solid-Edge-Files-from-th...
Or look at C:\Program Files\Solid Edge ST10\Custom\Batch\Bin\Batch.exe
All right, it works
Thanks.
