export more dft-pages, to single dxf file
hi,
I have a draft, with several pages.
i want to export some of these to a dxf file.
how to do that?
i tried the batch program, but cant get it to convert, more than a single page.
hope that someone can help me.
Brian
Wabtec
Best regards
Brian Nielsen
Wabtec
Re: export more dft-pages, to single dxf file
Hi:
When saving the Draft as a DXF, click the Options button in the SaveAs dialog and change the setting to export all sheets as separate DXF.
After this you can use the batch macro which will honor this setting.
But as mentioned, if you want to export only a few sheets from the draft to DXF, then manually making each sheet active and exporting the active sheet is the only way.
Tushar
www.SurfAndCode.IN
