floating license tracking
Hi all,
I have question about how to track or see taken license on solid edge floating license by who or by which client.
Thank you very much
Destian
Re: floating license tracking
i tried this, it didn't work
In Servers.txt file You must set Your Solid Edge server addres (port number@server name).
SE ST9 + TC 10.1.7
I do use this sentence in the windows command console:
c:\FlexLM\lmutil lmstat -c c:\FlexLM\SELicense.dat -a
Of course you need lmutil.exe and SELicense.dat in the c:\FlexLM\ folder to work.
A newer version of that utility lives here.
http://licenseuasageforflexlm.codeplex.com/
LMGi
www.TLMGi.com
Helo Everyone,
Thank you very much for your prompt feedback, I'll try as mentioned above in customer site.
I have downloaded the sources, we'll give you an update latter.
Thanks & Rgrds
Destian
Hello Edgers,
does anyone know, if there is a similar program that works with new FlexLM manager for ST10?
According to several customers, after updating LM to latest version bundled with ST10, this great program stopped working.
EDIT: I have to correct myself: this tool still shows currently checked out licenses. But another neat feature of this tool was force checked in license if for example some user forgot to close SE and another user wanted to use that license. This function no more work with latest LM with ST10.
Ota
Siemens Genius Siemens Genius
Siemens Genius
Hi Ota,
what about http://jtbworld.com/ ?
Have you already tested ?
Hi Tomas,
thanks fot the tip.
No I did not tested it. In fact I am not sure what software from that link I should use. Quick searching for "licensing functionality" or something similar does not provide any useful result.
Ota
