gettin ...error in installation....
N/A
plz help.........the licence iz telin to exist the solid edge session........wat 2 do..........?????
Re: gettin ...error in installation....
When installing Solid Edge, it is best to install it outside of cSmiley Tonguerogram Files because of Windows UAC. UAC makes "Program Files" read only and thus you cannot edit the License file located within a sub-folder in that directory which is causing your issue.
Production: ST10 MP6
Testing: SE 2019
