grouping
Not applicable
I'm attempting to group several lines and rectangles to form "a part". The help
instructions do not appear to work as advertised. Does anyone know how to group
objects properly?
Paul
Re: grouping
Not applicable
Select the elements and click the Accept button (Checkmark).
Give the group it's name and click the Accept button.
It is now a group. Check the Groups pane in Edgebar as it will list them.
Keep in mind that if the Selection Tool order option "Bottom Up" is set, you
will need to use QuickPick to locate the group (default is "Top Down").
http://grundey.blogspot.com
"paul liewert" wrote in message
news:48dbc56f$1@bbsnotes.ugs.com...
> Hi,
> help
> group
> objects properly?
> Thanks,
> Paul
