how do i open assy.step files in solidedge
i have an assembly file that is in step format.
how do i open it in solidedge ?
Re: how do i open assy.step files in solidedge
You have 2 options:
1-Open as an Assembly *.asm:
If the Step file contains a couple of different parts, that you could use in different Assemblies.
2-Open as Par *.par:
If the STEP file contains only one Part, or you do not need to handle different Parts and save them seperately.
Yasser
