how to change setting of scroll to zoom in -out from pan in drafting
how to change setting of scroll to zoom in -out from pan in drafting.
presently i am in st6 draft and when i scroll, whole draft sheet move up or down.
i want -when i scroll sheet should be zoom  in or out.
How to change setting.
1 REPLY 1
Go to Solid Edge options while in Draft and Click on the...
Go to Solid Edge options while in Draft and Click on the Program Button in the upper top left.
Then go to View and you'll see this:
