how to clean this corner?
A basic question... Man Embarassed
How do I clean this corner easy?
Thanks!
Solid Edge ST10 & AutoCAD 2018.1 user
Re: how to clean this corner?
Esteemed Contributor
Hi Joris,
You could just go back in and dynamic edit the angles of each end of the two flanges, to form a mitre......or reconstructing using a "Contour Flange" instead is another option.
Try what Sean has said then use the 'Close Corner' command
HP Z420 16GB RAM
Quadro K4000
ST10 MP3 on Windows 10 Pro 64.
Actually I tried running "Close 2-Bend Corner" but it failed for some reason, I didn't spend time on to identify.
On the "Contour Flange" ribbon bar there is a setting in the options to close the corner within the feature scope. [as attached model]
After changing the angles to 45deg use 'Close 3-bend corner'
HP Z420 16GB RAM
Quadro K4000
After changing the end angles to 45⁰, even "Close 2-Bend Corner" works.....soo many ways to get to a result! Robot Happy
Not sure about that bend radius on 4mm material though. Robot wink
Thanks both!
Sean,
That's odd, because I can't get 2-bend corner to work.
I tried all the different treatments but always get a message -
"The selected bends do not form a valid 2-bend corner.
The bends must share a common face"
HP Z420 16GB RAM
Quadro K4000
beachcomber wrote:
Sean,
Well, if there's an ODD way to do, or find things....I'll be one of them. Robot wink
"Well, if there's an ODD way to do, or find things....I'll be one of them."
There's always one ;-)
HP Z420 16GB RAM
Quadro K4000
