how to draw a tooth like line
Not applicable
Hello everyone,
I also want to draw a nut and a bolt with screw in it. I checked Sketching options
and couldn't find such option to draw a tooth line.
Can anyone help me?
Thanks in advance,
Jack
Re: how to draw a tooth like line
Not applicable
Jack,
I assume you are talking about drawing zig-zag lines that represents a cross
section of the thread. On mechanical drawings threads are not represented
this way. They are displayed in a simplified manner. If you are looking at a
bolt from the side, the major diameter is represented by two parallel solid
lines (bolt diameter). The minor diameter is represented by two parallel
dashed lines (represents the thread depth).
Rick B.
