how to export (.part) to (.Dwg).???
Hello guys.?
How we can (.Asm) or(.Part) 3 d model export to (.Dwg).???
Electron_jaal
8 REPLIES 8
Re: how to export (.part) to (.Dwg).???
Hi @Electron_jaal87,
No direct method to do this from SE,....that I know of.
Actually you dont know or this is impossible.???
@Electron_jaal87,
Well yes, that is what I meant...you cannot save a 3D model file to DWG from Solid Edge "directly"...you need to use a neutral format, such as ACIS [.SAT] file, etc.
There is also, this 3rd party app [Add-In].... http://www.sycode.com/products/dwg_export_se/
Sure special result
In solid edge you need to use "save as translated" and choose .sat format.
In AutoCAD you need to use the command "import".
Solid Edge 2020 & AutoCAD 2020 user
@SeanCresswell,
What about the approach of Imics "https://www.youtube.com/watch?v=5v0GL1jJNe4" Solid Edge - Save as dxf from model !
It works for 2D models with [ST5;ST8]
Many thanks to Imics for the very good tips and triks...
@YD, yes ageed, the things @Imics comes up with are truely amazing.....however, I think the OP was specifically looking for 3D AutoCAD [DWG or DXF] output from Solid Edge, rather than 2D.
