how to format a table in DRAFT
Good morning to all, is it possible to change the line thickness for a table grid? or the colour of the text inside a table?
I can't find the relative commands
Thank for your help
3 REPLIES 3
Betreff: how to format a table in DRAFT
Hi @Buscetto
Yes of course.
But not via the table option dialog directly but from the style settings sheet
When using a table You always use a table style (see picture)
And those styles are defined and modified from the View Tab  and Styles button
Create Your own style or change one of the existing according to Your needs
Wolfgang
thanks for your help
Appreciate
Hi @Buscetto
has this solved Your problem?
If so, You might set the answer as solution to show it to others
Wolfgang
