how to get the dimensions of hole Like M6 or M4 in draft environment
  i need to know how to get the dimensions like M6 or M4  of a tapered hole l in drafting.
Varunkumar.V.B
Technical Engineer
SHUBAN TECHNOLOGIES
D.No: 973-974,3rd Floor,
[Opp.Olympus Bus stand]
Trichy Road,Ramanathapuram,
Coimbatore – 641045.
Phone No : 0422 - 2321316
Mobile No: +91 9600440855
Email Id: varun@shubantech.in
Website : www.shubantech.in
Re: how to get the dimensions of hole Like M6 or M4 in draft environment
The first time you have to "teach" SE what you want:
Go to
"Style"
Dimension
Your style
Tab: Feature Callout
Fill "%TS" is:
Now use smart dimension, you can dimension the arc or the circle:
Solid Edge 2019 & AutoCAD 2019 user
Hi there,
I just use a callout, as normally I like to put some further text ahead of the referenced input.
Testing: Solid Edge 2019
