how to make a solid out of self closing surfaces?
N/A
I have an object which consists of surfaces which close each other with their edges. I want to fill this object with solid- to give my object mass. Is it possible?
Re: how to make a solid out of self closing surfaces?
Esteemed Contributor
Hi there,
Yes, you can...what you want to do is run the "Stitched" command, select all the surfaces and you get a solid body...
Solid Edge ST10 [MP6] Classic [x2 seats]
N/A
Thanks a lot. coz of having not discovered that function I even thought that Solid edge is not so cool. But it still is. THANKS!
