how to make draft template which is linked to 3d model????
3 REPLIES 3
Re: how to make draft template which is linked to 3d model????
Not sure what you are asking...
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
we know that , in drafing we have draft template on right bottom corner of the sheet. and it is linked to the 3d cad model. example , if we place date, scale, name,  on the 3d model in file properties of category, manager and tiltle respectively , it will reflect on the 2d draft sheet. how???? can anyone tell me???
It sounds like what you are wanting is Property Text.  This can be placed in the template (on Background Sheet) and setup to reference the first attached model in a drawing view.  Any exposed property of the 3D model can be referenced.  Typically I create a drawing view in my draft template of a model, setup property text how I want it, then delete the drawing view and save the template.
