how to sweep with multiple path???
 I am trying to sweep protusion with multiple path. Please see the attached file (created in ST8/Student Version)However, I can't make the protrusion, Could someone please tell me how to do it. i also attach screenshot image . I appreciate your help.
Thank You,
Betreff: how to sweep with multiple path???
I would like to say, this isn't a sweep with mulitpke pathes.
There is one path along for two profiles.
There should be a tutorial covering this issue.
Wolfgang
Re: how to sweep with multiple path???
MLombard
Retired
In the Sweep options is a check box for multiple profile sweep, which is what you are trying to do.
If you add another "path", you could create a loft, or a Bluesurf.
