how to update a model used in keyshot
Is there a way to update the SE file used in Keyshot with out lossing the assigned materials in keyshot?
I can not seem to find this. When i use the update button in SE while Keyshot is open, the file is reloaded and all parts with assigned materials are lost. Is there a way to keep these assignments while updating a file?
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
Re: how to update a model used in keyshot
Save your keyshot file as same name like your assy in the same folder . And try it again!
BR,
Imics
