how to use 3-bend corner treatment of sheet metal in ordered environment
HI,
 How to use 3-bend corner treatement command in sheet metal orderd environment.if you can explain it through a video it would be very helpful.
Re: how to use 3-bend corner treatment of sheet metal in ordered environment
Esteemed Contributor
Hi there,
The easiest way, is to hover your cursor over the tool you want explained, then press "F1" to run the "relative" help file.....but basically, it is exactly as described & illustrated below.
Honored Contributor
Honored Contributor
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Honored Contributor
Honored Contributor
(view in My Videos)
Honored Contributor
Honored Contributor
I posted two vids for this.
The first one shows how it can work and that you have to satisfy some conditions for it to work (like the flanges not overlapping to start)
The second one shows some way I would expect it to work and it does not.
These issues are way down on my list of problems with the software.
The first is: Need bend tables with back gage and stick out
The second is: I want tobe able to turn off changes to flat when bending.
