import new .asm in .dft
Hi
I am using SolidEdge for about 3 years now making small projects using .asm and .dft.
now I have a draft file using 1 main .asm but now I would need to get views of a 2nd main .asm but I can't find how to get it.
I am wondering if it is possible and if yes, how can I do it?
Edit: I am using ST4
Re: import new .asm in .dft
Hi there,
When you use "View Wizard" to place the new assembly file view[s], select "Browse" button to navigate & select the other file[s].
Testing: Solid Edge 2019
