import step question
I have a simple step file from pc-dmis with a plane, some lines and a bunch of points. I import the file and see the plane and lines but not the points...? Is there a trick to see the points? I tried importing into a part file and also into an assembly...
thanks
Re: import step question
Solid Edge cannot import point data from STEP files.
How about iges?
Solid Edge cannot import point data from IGES either.
If you can find a way to get the points into Excel you could use Curve by Table command.
There is a line segment option that will give you a locatable vertex at each point location.
I would like to see the file.
LMGi
www.TLMGi.com
As both IGES and STEP are text files, it would fairly easy to parse the data and extract all point data into a .csv file for use by Excel, which in turn could then be pushed into Solid Edge.
If you could provide your sample file for review.
Thank you and regards,
-Dave
I will try the Curve by Table command with line segment option.
Solid Edge can import a dxf file with point information... problem solved.
