import to KeyShot gives scale issues
Once i have my model set i import it into KeyShot with the SE import button. I then apply materials as need to adjust the camera position and orientation. But after its perfect i move a part in SE, i save and tehn reimport to Key. When the model comes in the scale and "camera position and orientation" changes. is there a way to stop this from happening? notice the numbers in the "camera position and orientation" chagnes.
Capture2.PNGfirst importCapture.PNGsecond import
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
