importing cordinates from text file or other format
N/A
i would like to enter hole location - i have all the cordinates and hole deph in exel / text file is there an automatic way to do that.
Re: importing cordinates from text file or other format
You can write a macro which reads the text file and creates all the holes features for you, but I don't know, if the API support is enabled for the SE Student Edition. Something you have to check.
